Lexus Rims Compatible with LS430
I have a 2003 LS430 and the stock 17 chrome rims are flaking and leaking air. I dont want to spend a lot of money on new rims and would prefer to get used non chrome rims off craigslist. I've been trying to figure out which Lexus rims are compatible since I hear the front brake calipers are larger than average. This website has recent Lexus models vehicle bolt pattern
http://www.discountedwheelwarehouse...._Reference.cfm
It says that the LS430 has 2003 5 lug 4.5 inch or 114.3mm High Positive Offset.
Does that mean that any other Lexus vehicle rim with the same specification fit with no problems.
example will 2009 Lexus HS250 5 lug 4.5 inch or 114.3mm High Positive Offset rims fit my ls
Super Moderator
More than high positive offset comes into play. Wheels that fit are limited to the LS 95-06 years. 2-IS 350 and 3- GS350 and onward years/models. Aftermarket wheels need high disk-BBK clearance for the spokes. So inquire with the seller or manufacturer if their wheels clear big brakes. Otherwise, you'll be needing 10-15mm spacers. The HS wheels will not likely clear the calipers.
one thing that I vaugely remember is the IS and GS sometimes have offset wheels front vs rear. Does that usually mean same size wheel but different tire size ?
Different size front vs rear is referred to as staggered.
Daspyda
07-29-17 07:11 AM
