Check VSC message after battery tested?
I have a 2003 LS 430 and had the battery tested recently. The Check VSC message has come on in the process. I have since replaced the battery and the message still appears.
I have read other threads in this forum and disconnected the negative from the battery. I waited a couple of minutes before re-connecting. I still get the message. Any ideas whether this is related to my battery testing/replacement and how to clear the message? Thanks!
After further reviews from other threads, I resolved the "Check VSC" message on my 2003 LS-430:
1) Insert paper clip as jumper into the DLC3 connector under the dash into TE (top row - 3 from the left) and CG (bottom row - 5 from the left)
2) Turn car to ON (not start)
3) ABS light starts to flash and then after several seconds the "VSC Test" display comes on
4) After a few more seconds, turn car off
5) Remove jumper (paper clip)
6) I started car and drove for awhile and it hasn't come back on.
Thanks for everyone that took the time to post their insights on this issue!
DaveGS4
02-06-05 11:32 PM
