2003 LS430 - Transmission Filter???
Hello,
Does this car have a transmission filter? I've changed the fluid on other cars and they usually do, though on this one I can't find a part number.
Thanks
Thanks
Often referred as ' valve body strainers '...
Here is a link ar Rockauto..
https://www.rockauto.com/catalog/x,c...2B4.3L%2BV8,ck[ID],0,ck[idlist],0,ck[viewcurrency],USD,ck[PHP_SESSION_ID],jntck68setsvvebbh4ji74ggi2
For 2003 LS430, Factory Maintenance Schedule mentions "Inspect transmission fluid" at 150,000 miles. No mention of replacing strainer.
See https://secure.drivers.lexus.com/lex...ce-schedule.do
Select "2003", then "LS430", then "Show me the details", and then "Guide" for all factory recommended maintenance services.
I've replaced lots of transmission filters, each time I've wondered why I did it. Every one I've looked at had a bid of clutch dust in them but still had plenty of life left.
This forum suggest a fluid change procedure without pulling the pan. The procedure replaces eight quarts of fluid instead of just three and and is much easier. Go to the "how too" section. I've done it and it works.
Thanks for all of your help!
