probable causes of gas smell under hood 03 LS430
Old 09-29-14, 10:33 AM
mofoco
mofoco's Avatar
Default probable causes of gas smell under hood 03 LS430
Have strong gas smell under hood after driving...Any trouble shooting tips?
Old 09-29-14, 05:55 PM
rkw77080
rkw77080's Avatar
Here are a couple of drawings showing your fuel system under the hood. The engine is fed by a single fuel line from the tank. It's connected to 2 fuel delivery pipes each with a pressure pulsation damper. Each fuel delivery pipe supplies fuel to 4 fuel injectors. The o-ring is usually the first part to fail. The best time to find fuel leak is when the engine is cold, for 2 reasons: 1) materials typically expand when heated (leak decreases), and 2) the leaked fuel, if heated, will evaporate quicker and become more difficult to detect.
Old 09-30-14, 07:36 PM
Arcturus
Arcturus's Avatar
+1 on a possible leak from one of the fuel injector o-rings. As rkw77080 says, check when cold. This is when the parts will have the biggest gap.
Since the system is under a lot of pressure even a pinhole leak will spray fuel out.
After first starting the car look for a wet spot that smells like fuel near the top or bottom of each injector. If you see it, get some new o-rings, relieve the pressure in the system (usually by pressing a Schrader valve with a rag to catch the fuel - not sure on this vehicle though), remove the injector and replace the faulty o-ring. Make sure you release the pressure in the fuel rail before working on it or you may get a nasty surprise!!! Should be a very cheap fix.
I had this problem on an old pickup when I replaced the intake manifold. I put new o-rings on the injectors after I removed them, but they were aftermarket and didn't fit well.
menty
Performance & Maintenance
06-12-21 05:01 PM
khalid80
10-19-18 11:27 PM
mafpolo
03-03-14 07:44 PM
bryanc182
06-30-10 05:06 AM
dmd85059
01-21-04 05:20 PM
Quick Reply: probable causes of gas smell under hood 03 LS430
