Changing Tire Size
Old 11-18-14, 08:17 AM
Coriaty1
Coriaty1's Avatar
Default Changing Tire Size
Asking for an opinion here..
I have an '04 LS with the Sport Suspension and 18" wheels. The tire size that came with the car is 245/45 18 and I am thinking of replacing them soon, but with one sidewall ratio larger 245/50 18. I think the extra height will fill in the wheel wells nicely and improve the ride with the sport suspension.
What do you think?
Charles
Old 11-18-14, 10:19 AM
doodoo
doodoo's Avatar
What do you think?
Charles
The tires will fit and the sidewall will be bigger making your rims look smaller. Just to let you know, using a tire calculator a 245/50 is almost an inch taller than the 245/45. As for the ride aspect it should be a smoother ride but probably not significant difference. Since changing to a bigger tire like that, also perform an alignment after, as your height will change with taller tires. I personally would just stick with factory size, the LS still has a very comfortable ride even with the sport suspension.
Old 11-18-14, 10:59 AM
Lavrishevo
Lavrishevo's Avatar
Here you go:
http://www.miata.net/garage/tirecalc.html
A 225/50/18 would be closer to keeping things stock.
Old 11-18-14, 06:22 PM
KING
KING's Avatar
Does the Michelin MXV4's come in that size?
Honestly, you'll never find a better tire than that one.
Old 11-19-14, 07:19 AM
RushNatU
RushNatU's Avatar
Your car will accelerate and brake slower with larger diameter tires. Speedometer will also be off.
Old 11-19-14, 06:45 PM
Coriaty1
Coriaty1's Avatar
Yes the more I'm reading up on it, the more I think I'll stick with the original size. I'm running on Michelin Pilot Sports right now I find them pretty quiet but hard riding. Maybe the MXV is the way to go..
Thank you all!
STREETGS
10-13-21 04:34 PM
Jxlee0215
03-07-18 07:50 PM
BLK98GS3
13
06-06-12 03:18 PM
TomLS
05-16-10 05:42 AM
infiniti24
SC- 1st Gen (1992-2000)
13
03-18-10 10:55 PM
Quick Reply: Changing Tire Size
