CD eject/Load problem
Some blank CDs may actually be a bit thicker and cause an eject problem. If you're using a high quality CD you will likely never have a problem. Just stay away from cheap blank CDs. In my opinion.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I used to have this problem with my original Xbox video game console. The super expensive Memorex 4x CD-RW discs were the only burned CD's that worked because they weighted the same as real CD's. The cheap CD's didn't always work.
Well, I have to thank you guys for all this information. My wife's LS430 CD player displayed the "CD Error" and stopped playing and a local shop quoted me $380 to $450 to replace the drive depending if it was the Pioneer or Nakamichi (I was uncertain which one her vehicle has).
Did the "remove battery cable" technique and sure enough a CD ejected out of the carrier. I removed the 5 other discs, turned the power off, waited a few seconds, powered back up and reloaded and played all 6 CDs with no issues.
Thanks again!!!!!!! This is a great group of folks....
so I know this is rather long after the original post, but, I did the whole "disco battery" thing and it didnt work. Cd's were still jammed. then a random day I noticed the deck no longer said it was full so I ejected a Frank Sinatra disc. cleaned it put it back in and another disc and its back to being stuck.
Jontay
07-22-21 08:23 AM
