remove half shaft
remove half shaft
anyone has any idea how to remove/replace the rear half shafts on our car? Not much info on search, mine popped out a little and I need to see if I can just hammer it back in or is there something else I need to do first.. thanks in advanced. I also posted under VIP sections, assuming those guys deals with axle pops all the time.. hehe
once you click on the links, you have to manually find them (m_sa_0058). From what the link is saying, it look like I can just push it back in, and if need to, remove the LCA. I didn't have any time to work on her today. So hopefully this weekend.
I clicked on the links, but none of them will connect to anything...
I asked only to make sure you have what you need to proceed. I already have a hard copy of the Repair Manual, and as you said, you can just push/hammer it back in as shown below.
thank you!! I was planning on hammering from the hub, but this make its more easy. I was scared to do this at first because I didn't want to crack anything, but this comfirms it and will make it easier since I will be pushing it in closer to the actually hole. Thanks again! Will let you know how it turns out! hehe
I've had this happen on my 4 wheeler..
Which makes me ask... Is there a snap ring on the end of this shaft that serves as a keeper?
On my 4 wheeler the snap ring had come off and let the shaft slide outward
the pic rkw77780 posted mentions a snap ring.... What snap ring is the manual referring too?
Continue on as you were, I apologize for any confusion
Below is a link to the breakdown of the differential
http://http://www.lexussouthatlantaparts.com/showAssembly.aspx?ukey_assembly=790508&ukey_make=1082&ukey_model=15670
