Check your spare tire - it's low on air.
Old 02-25-15, 05:23 PM
Jabberwock
Jabberwock's Avatar
Default Check your spare tire - it's low on air.
The LS430 has a nice wheel and full size spare tire in the trunk but most folks (including me) don't check it regularly. I had not checked my spare tire in a couple of years so today I pulled the spare out to check pressure. The pressure was down to 17-18lbs. I put 32lbs pressure back in and reinstalled the spare in the trunk. The whole deal took me 15 minutes or so. Check your spare yearly because if you need to use the spare it won't be very useful if it is near flat.
Old 02-25-15, 06:14 PM
KING
KING's Avatar
Good practice to check your spare every now and then.
Old 02-26-15, 06:35 AM
randal
randal's Avatar
I check my "spare tire" every morning. Still fully inflated, dang it! ;-)
Good reminders, Jab. Another thing to think about is the age and cracking of the rubber. It also might be a good idea that, when you get new tires, to rotate a worn tire for that spare if it is over a decade old. Even with practically unworn tread, it is not as safe as a newer, but worn, tire would be.
Old 02-26-15, 07:44 AM
daddykay24
daddykay24's Avatar
Same thing happen with me. I had not checked mine in 5 years. Needless to say, it was completely flat. I make it a habit to check it more often now.
Old 02-27-15, 12:32 AM
JffGRY706
JffGRY706's Avatar
would be easier to check if I did not have to remove tire to do it. I wish it fit the other way. my days of changing flat tires just might be over.
Old 02-27-15, 05:28 PM
aypues
aypues's Avatar
I think the dealer does this whenever I take it in for service.
Old 02-27-15, 05:42 PM
empringham
empringham's Avatar
i blew a tire out on my LS as i am one of those deviants who lower it too much and intentionally run negative camber. Lucky i was able to drive 40KM's on my spare, it was quite low, would recommend this to all of you guys.
I think the spare on my toyota soarer is filled with foam. Wonder why they stopped doing that.
takadakeyo
07-06-24 07:59 AM
peasodos
04-18-19 11:47 AM
Magellan55
HS 250h Model (2010-2012)
09-11-16 07:40 PM
jimbosr1
SC- 1st Gen (1992-2000)
12
03-15-16 07:42 AM
johnnylt
09-14-15 11:29 AM
Quick Reply: Check your spare tire - it's low on air.
