What is the Engine oil capacity for the ls430?
#46
I had planned on changing the oil anyway when I got home to start my maintenance records and choice of oil, so my oil change was scheduled for Friday (2 days ago). I did the oil change at a DIY shop (I rent a lift and do it myself). The car was level and I let the oil drain out for at least 30 min (with the fill cap removed from the top) to ensure I got as much oil out of the crankcase as possible. The oil that came out was very clean as the service history of this LS was immaculate and serviced at the local Lexus dealership, but that doesn't always mean the lube techs take their time and fill properly as they are sometimes rushing the cars out of service to make way for the next vehicle unfortunately.
Anyhow after reading this thread I made sure to start with 4 qts and top off from there as I didn't want another occurrence of overfilling. I ended up at 4.6 qts which brought it right below the full mark (1/8' below to be exact). So this whole thread of some filling to 5.4 qts and others @ 4.8 qts is very interesting unless Lexus changed dipsticks which doesn't make sense, but neither does filling this particular example up to 5.4 qts as it would be over filled per the dipstick that came with this car🤔🤷♂️
Just wanted to chime in and see what others have to say about the capacity on these motors. Coming from filling my ISF at capacity with a crankcase of 9.8 qts on the 2UR-GSE we have learned that filling @ 9.8 - 10 qts (believe it or not some owners have done 10 qts because they buy two 5 qt jugs and dump both in) causes the back 2 cylinders to take on oil in the spark plug tube seals which eventually foul out those particular spark plugs and it's best to fill @ 9.5 with the ISF to avoid overfilling. So I'm a little cautious about overfilling the LS430 when I've been use to running 1/4- 1/2 qt less than what is stated for the ISF.
Thoughts on this?
