Bilstein Coilover need identify
Just a wild guess here. But if the white text prints on the blue coils mean spring rates, then the higher stiff rate should usually be in the front.
So, 12/2002 front, 11/2002.
Just a wild guess.
Just a wild guess.
It looks as if the two on right are for rear. To make sure look at the hole at the bottom of the coilovers. The rear has a bigger hole on one side and a smaller hole on the other. And the fronts have a same size hole on both sides. The hole that you insert into the bolt. Hope you get what im trying to say.
What they said ⬆
Bilstein numbering system is user friendly.
For example, if the coilovers were left and right specific the numbers would look like below
6668 - Front Left
6669 - Front Right
6670 - Rear Left
6671 - Rear Right
Since you have 2 of each -
6669 - Front
6670 - Rear
6668 - Front Left
6669 - Front Right
6670 - Rear Left
6671 - Rear Right
6669 - Front
6670 - Rear
XenonDepot
Club Lexus Vendor Marketplace
05-17-18 08:04 AM
