Audio, Climate and Nav Stopped Working
Everything was working fine this morning on my '02UL until I made a stop. When I restarted the car, the audio, climate and nav were not working. The screen came on with the tan Lexus logo and the acknowledgment screen but then went blank. When I turn on the radio, it says "audio off". When I turn on the climate, it says "check air conditioner" connection.
I need to check the fuses. I have a feeling that it may be related to the Vais unit or the harnesses that it is plugged into, so I may disconnect it. Does anyone have an idea on the air conditioner connection? Any other ideas or suggestions are welcome.
At the risk of jinxing the solution, I believe I have solved the problem. I disassembled the center stack and checked the Vais cables. Applying pressure to a connector and using a small flathead screwdriver to lift the locking tab on one of the other connectors, I was able to reestablish the connections. The audio, climate and Nav all returned to normal, for now at least. If it happens again, I will probably replace the Vais cable and go from there.
raybear
01-23-19 08:45 PM
elschenko
GX - 1st Gen (2003-2009)
11-04-14 10:30 AM
