humming or slight vibration when moving wheel to left while driving
Humming typically comes from failing hub bearing, and the humming is usually worse when you make a turn. Try lifting each front wheel off the ground and manually rotate it to see if you can detect unusual noise. BTW, what's the age of your car and how many miles do you have on it?
02 ls 430 170000
