Nagisa Auto Blocks vs. Youzealand SS Kit
Can anyone confirm the differences between the two? I have seen posts claiming that they do the same thing but I believe that the Nagisa pieces add negative camber along with the other changes that they both accomplish.
I have the Youzealand kit right now and when I am aired out I have probably 2-3 degrees of negative camber. I would expect more if they both do the same thing (add camber, fix caster, make lower).
How can I tell if I have the Pro or Regular kit in front? Also where do people buy the Nagisa blocks? I'd like to get a little more camber up front to fit a bigger wheel.
Thanks for the info.
I don't know which is on my car since I bought it with the kit installed. I'll have to take a look but I believe the OEM ball joint mount were in a box of parts so I probably have the Pro.
