2003 LS430 - Wheel Hub - Directional?
Hello,
A while ago I got a "Check VSC" and an "ABS" warning light. I checked it and it was for the front left wheel sensor. I bought a replacement hub and sensor assembly from Sewell, but never got a chance to put it in. Shortly there after the "front left wheel speed sensor" alarm went away, but I got another alarm for the "front right wheel speed sensor".
Recently I decided to change out the right front wheel speed sensor with the hub that I had bought and received (for the left side). However I am still getting the C0200 message for the right front wheel speed sensor.
I read in another thread for the LS460 that the problem was traced to the sensor being set for the other side and the car thinking that it was going in reverse.
Are these sensors directional? The part number I ordered was 4355050011 and when I go to Lexus of South Atlanta I get:
http://www.lexussouthatlantaparts.co...roduct=5752650
To me this is very confusing as there is a 43501C(RH) and a 43502C(LH) but the part numbers are the same. If it is directional can I reprogram it somehow to reverse the direction?
Maca1281
04-22-24 01:54 PM
ES2501990
19
10-23-16 07:49 AM
Arcturus
05-17-15 07:47 AM
