Stock Oil Pan Bolt Thread Size
Old 06-25-15, 05:29 AM
propcop
propcop's Avatar
Default Stock Oil Pan Bolt Thread Size
Changed the oil last night only to find out that the last guy to touch the oil pan bolt must have stripped the aluminum threads in the oil pan.
The first give away was it took a 9/16" wrench to loosen the pan bolt, not a metric size wrench and didn't come out like I expected, it kind of dragged it's way out. When replacing the bolt it went beyond the tightened position.
The bolt diameter removed measured .465 inches diameter, not sure what that relates to, maybe a 12mm bolt. Now I need to purchase a Time-Sert kit or a Heli-Coil repair kit just not sure which one to purchase.
Anyone else have this happen to them?
Thanks for any suggestions
Old 03-29-16, 02:57 PM
aypues
aypues's Avatar
My car is at service now at the stealership. They are telling my my oil pan has stripped drain plug. They are the only ones that have ever touched it. Am I out of my mind to tell them to replace the oil pan at their own expense since it's their own fault?? they said it would cost $575!!!
Old 03-29-16, 03:20 PM
BradTank
BradTank's Avatar
If you have a stack of receipts showing they have been changing the oil for a long period of time, I would say you have an excellent case.
My guess is once though it's in their lap, they'll come up with a cheaper solution like using a tap and putting in a larger drain plug rather than replacing the entire pan.
Old 03-29-16, 05:30 PM
aypues
aypues's Avatar
well good news: they are comping it! I didn't even have to fight. I guess being a 17 year customer helps sometimes.
Old 03-29-16, 07:10 PM
Jabberwock
Jabberwock's Avatar
Good job not getting hosed by the dealer. If they have been changing your oil exclusively and your oil pan is stripped it is 100% their fault. The oil pan bolt on the LS430 is super easy to loosen and tighten with a socket wrench. There is absolutely no reason the pan threads would strip or wear out unless some mamaluke tech forced it.
Old 03-29-16, 09:38 PM
airchomper
airchomper's Avatar
The oil pan is probably steel, but it's definitely magnetic.
The head is 14mm and I believe it's an M12 bolt with a 1.25 mm pitch. I'd bet someone put in an imperial/SAE bolt and ruined the threads. However, if the bolt was aluminum, the pan might be okay.
Did you put the 9/16in bolt back in the pan or did you replace it with a proper bolt?
propcop
08-05-15 03:00 AM
lbintab
04-20-14 12:38 PM
lexus-is2
04-14-14 04:42 PM
SISMO817
GS - 1st Gen (1993-1997)
03-27-07 02:13 PM
Norcalex
Performance & Maintenance
09-02-06 05:53 PM
Quick Reply: Stock Oil Pan Bolt Thread Size
