Vaistech MML
I have just installed a Vaistech MML.
Being and old fashioned sort of guy I always play albums. What is the best way of being able to browse through my albums. Can I do that with playlists on my iPod (never used a playlist) or is it better to install a HD?
Each album can be a selection on your playlist. If your iPod is the older one which had a harddrive with 160GB, you can have 100 albums in one playlist. Only way to go.
After some experiments with playlists in the end I choose "Simple Mode". This means I control the search for my music on the iPod which has a great interface. I still get the advantage of being able to skip or repeat a track from the centre console or steering wheel.
I have routed the harness into the arm rest just under the 12 volt connection. I have just enough wire to connect to the MML but I will need an extension before I mount it permanently (with velcro). The ipod is on the shelf in the arm rest. It is a bit basic but it works for me.
Almost forgot. Its almost worth it only for the automatic "I Agree" function!
