Changed my spark plugs today........details
Old 07-07-15, 03:54 AM
swfla
swfla's Avatar
Received 1,275 Likes on 985 Posts
Originally Posted by jpv7774
samsung galaxy s5 16mp pic.......
Attachment 365684
The plugs look average to me. That's good for the amount of miles. Did you clean the 2 MAF sensors? They're under the silver LEXUS cover, a few squirts of cleaner and you're done. Cleaning the throttle body takes a little more disassembly, next time you're that far, a few squirts and you're done. I believe that the PCV valve is buried deeper in the engine and is the type of item worth a few squirts when you're that far.
Old 07-07-15, 05:49 AM
KawiLex
KawiLex's Avatar
For 135K the plugs do look good. I was not aware of 2 MAF sensors, just the one on the air box.
Old 07-07-15, 06:01 AM
swfla
swfla's Avatar
LS 460 has 2 MAF sensors. Not sure about 430.
Old 07-07-15, 06:11 AM
Lavrishevo
Lavrishevo's Avatar
Just one in the 430. And a hell of a lot less control arms that don't go bad at 60k miles...
Old 07-18-15, 01:23 AM
MOBK1106
MOBK1106's Avatar
did any of your connectors break?? Toyota/Lexus are know to having very brittle plastic connectors at certain point
Old 07-18-15, 03:43 AM
JffGRY706
JffGRY706's Avatar
Denso recommends 60,000 service life for iridium plugs, Lexus recommends 120,000 . kind of like they recommend lifetime transmission fluid that they do not make. discuss
Old 07-18-15, 05:58 AM
jpv7774
jpv7774's Avatar
Im not sure which connectors u are asking about.....but I did not break any clips or boots.....but I really took my time with this project. No real noticeable performance improvement.....except in my mind......but I believe the service needed to be done.
Old 07-18-15, 06:28 PM
Bocatrip
Bocatrip's Avatar
This is the very reason that at 119,000 miles with my 01 LS430 running like a champ and accelerating and idling perfectly, I have decided to hold off on the spark plug replacement. I only drive 5,000 miles a year which shouldn't change things very much. .
Old 07-19-15, 04:02 AM
swfla
swfla's Avatar
Boca, a reasonable assumption. If you're handy, it may be interesting to remove one accessible plug for inspection. But that's just my curious personality.
Old 07-19-15, 12:32 PM
KawiLex
KawiLex's Avatar
The 2nd or 3rd plug on the driver side can easily be removed in a minute without the socket attachment that has a universal joint. That socket attachment is required for some of the other plugs, along with the extension.
Old 07-19-15, 08:44 PM
jpv7774
jpv7774's Avatar
let it ride if u only drive 5k a year......u saw how mine looked w 135k on them. Im just a perfectionist. If u are handy I agree taking a quick look might satisfy your curiosity....but if your car is running great they will look just like mine did.
Old 10-19-15, 09:04 PM
campisi
campisi's Avatar
Attachment 365684
Interesting .... I was comparing my plugs (doing the timing belt) to these and mine look exactly the same in terms of wear. I have 94K on them. They are definitely the OEM plugs (I'm the original owner of this car) but my car came with NGK Iridium IFR6A 11 plugs as OEM. They're equivalent but I'm surprised that they are different manufacturers.
Old 10-20-15, 06:45 AM
jpv7774
jpv7774's Avatar
Ya no real performance difference after plug change but nice to know it is done. Not sure why they used diff plugs. I am impressed that u are tackling the timing belt.......u are saving a ton of money.
Old 10-20-15, 06:19 PM
semar
semar's Avatar
thanks for the excellent detailed instruction.
I wished there was something like it for the airsuspension to coilover on 01-03
Old 10-21-15, 07:32 AM
campisi
campisi's Avatar
yeah, I've got a ton of 'deferred' maintenence I'm doing right now. It's my wife's car and she's out of town for 3 weeks so I'm getting it all done. Main thing is T-belt but "while I'm in there" I'm also changing the plugs, replacing brake fluid & transmission fluid and I might take this opportunity to swap the air sus out for the OEM steel spring setup. I bought the complete setup on Craigslist a few years ago and have been waiting on the air sus to go out. Might just change it over and sell off the air components.
Quick Reply: Changed my spark plugs today........details
