Average lifespan of starter motor?
I have 91K on the original starter.
Also, my LS takes a bit longer to start than any other modern car I've owned. Always has, from the day I bought it. It seems like it takes longest to start on the first start of the day which is about a second. Subsequent starts are more like .5 second. I tried turning on the ignition and letting the fuel system 'pump up' before trying to start it and that doesn't make a difference. Warm weather / cold weather ... first start of the day takes just a little longer.
130k on the original starter
Don't want to jinx myself, but currently at 130k. Not sure what a 'bump' start is, but about 15% of the time, I'm guilty of releasing the key a milisecond too soon and the car hasn't started.
I then wait about 5 seconds, then hold key until she starts. During that 2nd evolution, about 10% of the time, I have to do a 3rd go around! lol. I just can't STANDDDD holding the key turned after the car has obviously been 'started', so I overcompensate on the short side.
My gf's 18 y/o daughter is INFAMOUS for holding the key too long!!!!!!!!!!!!!!!!!!!! No---she does not TOUCH the LS. As much as I try to educate/teach/instruct her, she beats her 06 Ford Focus enough as it is. She knows everyyyyyyyyyything.
Using your ear is the best method. I start my LS the first try I would say 95%. Bump start means engaging the starter for just a moment and on the LS this is not enough to start the engine. Sometimes she will start up more quickly but in general it's about 1/2 - 1 second. My LS400 acted the same way.
I am admitting I have not read the posts in this thread. However, I can say this is the first thread that had anything to do with our starters. Never heard a thing about a failed starter. However, as our cars age, new issues can arise. Never read one starter issue on this forum Sorry I could not be more helpful. Good luck.
I traded in my 02 GS430 when I got my LS and it had 170K on the original starter. When I had a knock sensor fail, it was recommended that I change the starter at the same time due to age and labor cost.
2KHarrier (04-15-17)
FYI, just hit 152K and no issues (10,000 miles since 01Jan17)
222,000 (137,000 miles) kilometres and still on the OEM Denso reduction type starter motor. I'll likely just throw a set of brushes at it, clean up the com bars and stick it back in. Those old Denso starters are solid as a rock, I just had my partner's one on her 5A-FE Levin done, just needed a set of brushes and it was good as gold
222,000 kilometres and still on the OEM Denso reduction type starter motor. I'll likely just throw a set of brushes at it, clean up the com bars and stick it back in. Those old Denso starters are solid as a rock, I just had my partner's one on her 5A-FE Levin done, just needed a set of brushes and it was good as gold
edit p.s I took pics of the replacements, to illustrate...the bar coding and labels were not only crooked, but in different places on each starter motor, just reinforcing the lack of quality control. And, they yanked the lifetime warranty. rebuilt original > new aftermarket imho. And if one has ever seen an operation in the USA rebuilding these things, it would be like seeing a hot dog factory and not wanting to eat them anymore...
