OMG! Starter mortor was died. I guess.
Dear Sir.
This morning, I was drive my LS to friends home. and stop my car about 1 hour.
After talking about with my friend, key-on my LS430.
But start fail my LS430
Sound is "keeeing~ keeing~ tick,tick,tick,tick,tick,tick,tick,tick,tick...."
My starter mortor was DIED, I guess.
So, I'm try to find the "Starter mortor" on e-bay.
And success found the some "Brand new starter mortor for LS430"
http://www.ebay.com/itm/2002-2009-LEXUS-SC430-2001-2006-LS430-2001-2007-GS430-4-3L-V8-STARTER-/130923959817?fits=Model%3ALS430&hash=item1e7bad1609&vxp=mtr
This model is made by TYC
Is it nice product?
Is it the product certified?
Is it believable product?
Please advise to me.
Thank you.
Is it nice product?
Thank you.
Are you sure it's the starter that failed? Tick, tick, tick sound can also be dead battery. Also, your alternator/voltage regulator could be failing if your battery is "new".
I agree with Tom57, load test the battery first.
Also clean and tighten battery cable connectors.
Many here would recommend the Denso starter as a first choice.
It is high quality original equipment.
Rebuilt/remanufactured is good.
Not necessary to buy new.
1) 을 다시 테스트하여 다시 새 배터리를 확인
2) 다른 자동차 를 사용하여 자동차를 점프 를 시작 하고 유휴 및 실행 , 그것을 가지고 계속 하는 경우 자동차 를 실행 하면서 테스트를 충전 해야 할 쇼핑 . 이 표시됩니다 경우 배터리 나 발전기 문제
위의 차를 점프 할 때
3) 경우 ,자동차 는 엔진이 시작 나던 의미 넘겨 하지 않습니다 - 당신은 일정 틱 다음 선발 문제 가있을 수 있습니다 틱 소리
4) 모든 가능성 , 그것은 나에게 죽은 배터리 같은 소리
위의 차를 점프 할 때
sounds about right
1) Test again to re-check the new battery
2) Using other car jump start the car and run idle and, if you continue shopping you need to have it filled while running the test car. If a battery or alternator problems are displayed
When you jump over cars
3) If, cars do not pass it doesn’t mean the engine is started - You may have a problem starting the next calendar tick tick sound
4) All the possibilities, it sounds to me like a dead battery
SuicidnS13
Performance & Maintenance
11-02-10 08:51 AM
