Front sway bar
Front sway bar
Hello Club Lexus
I've been doing some research on replacing the front sway bar bushing and believe switching to polyurethane will result in a somewhat sportier feel.
Question is has anyone done this mod and is the standard size 27mm.
Thank you
Thank you
It's going to be a really negligible difference in handling improvement. My concern is poly bushings can badly squeak unless they are lubed.
I personally don't think it's worth the tradeoff but it's a simple job to perform.
Poly bushings may also cause hard shutter when traveling over bumpy roads. While poly bushings may provide a little less sway and lean into corners, there is a trade-off.
Kajukenbo
Suspension and Brakes
10-29-02 02:50 PM
