My sick baby
#31
Was that one the zero point calibration? Or was it the one that pull the codes (and automatically clears them afterwards)? I know there are two ways of jumping the pins. I've done both, but now forget. Too late... To tired
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#33
Ok everyone. Everything is fixed and I got all of the spark plugs changed. While doing my last one on cylinder 2, I was screwing in the ignition coil. I was being very gentle and not over tightening it, and the bolt just sheared off. A part of the bolt is in the screw hole in the engine and now I can't secure the ignition coil. Ugh!!! This was literally the last step after three days of slow careful work. Thoughts????
#34
AN
#35
#36
I was doing it by hand, tightened it slightly with my wrench and it just broke off.
#37
This is the reset VSC procedure that I thought you were referring to: See post # 29 - https://www.clublexus.com/forums/ls-...c-vsc-off.html
#38
If there's room, you can try an easy out. This is just an example:
hhttp://www.amazon.ca/Piece-Easy-Screw-Bolt-Extractor/dp/B0002UJNWE
You should be able to pick one up at your local Pep Boys or Autozone. Good luck!
#40
Make sure you cover up any part of the car that will get hit with shavings from the dremel. Those little metal shavings could wreak havoc on your electric connections if the find their way into them.
AN
BDSL
06-02-12 03:14 PM
handoverfi
03-22-10 02:04 PM
colenzae
RX - 1st Gen (1999-2003)
27
08-11-07 02:54 PM
