P0430-Cat Efficiency Bank 2
Old 09-30-15 | 09:17 PM
Arcturus's Avatar
Arcturus
Default P0430-Cat Efficiency Bank 2
Hello,
Which side is the bank 2 cat on the exhaust? I'm getting this alarm a lot and the car is louder than normal. I suspect a crack in the exhaust as this is a common problem on this car. Just want to tell the mechanic where to look.
Thanks!
Old 10-01-15 | 02:06 AM
poplinux's Avatar
poplinux
passenger side, I guess
Old 10-01-15 | 05:04 AM
rkw77080's Avatar
rkw77080
Confirmed, Bank 2 is on the Passenger side...
Old 10-01-15 | 05:30 AM
Arcturus's Avatar
Arcturus
Great. Thanks! And the most common point of failure would be under the heat shield where it goes into the y-section?
Old 10-01-15 | 08:06 AM
Boomer01's Avatar
Boomer01
I continuously have this error code pop up. Like you said, it's most likely a small hole in the exhaust pipe. I took mine to an exhaust shop and they welded a small hole shut which seemed to help for a few months, but it's back. My next step is probably to replace the entire Y pipe assembly.
It could also be a bad O2 sensor.
Old 10-01-15 | 10:04 AM
BradTank's Avatar
BradTank
It could be a small leak, but a catalytic converter with a lot of miles can just become "inefficient" enough over time that it triggers a code and requires replacement to get it back in spec.
I had a similar code and had an exhaust shop that I trust check it out and not find any leaks.
Instead of replacing the factory cats, I just put one of these "extenders" on and never had another issue with the code. I got mine off of Ebay, but it was more of an angled one that could be rotated in order to fit since the exhaust is close to the body. I just grabbed these images online.
The purpose of that sensor is basically for state emissions testers to see if the catalytic converter is in spec and working properly, a "pass/fail" sensor. It's not going to effect engine operation.
Old 10-01-15 | 09:47 PM
Arcturus's Avatar
Arcturus
What does the extender do? Pull the sensor out of the stream?
Old 10-02-15 | 09:43 AM
BradTank's Avatar
BradTank
Yea, basically.
You would think it wouldn't "work" since it's still air tight but pulling it out of the direct exhaust stream fools the sensor enough so it's not an issue.
Old 10-02-15 | 08:10 PM
Arcturus's Avatar
Arcturus
Yea, basically.
Interesting! I'll have a look at that. Thanks for the info.
Soledad
10-20-22 05:49 PM
Frank2029
07-04-15 07:39 PM
BatKing
06-18-13 01:07 AM
bstains
06-27-12 03:16 PM
tomtheslac
08-03-11 12:25 AM
