03 LS430 slipping in reverse
Old 10-13-15, 11:24 PM
LS430670
10th Gear
LS430670's Avatar
Default 03 LS430 slipping in reverse
Just purchased an 03 LS430 and the trans seems to be slipping in reverse only on cold starts and is fine in drive.
Took it to the Toyota dealership and they recommended i change out the valve body.
Anyone else experience this particular issue on their 03 LS430? Any recommendations?
Thanks in advance from the noob.
Old 10-14-15, 12:26 AM
KING
KING's Avatar
Did the car ever have a tranny flush before? Maybe it's due for you.
Old 10-14-15, 01:02 AM
JffGRY706
JffGRY706's Avatar
if it is a 5 speed with a dip stick check the level and condition of fluid on the stick. does it smell burnt or dark in color? if your car has the lifetime 6 speed transmission.....good luck. Was the car imported to Siapan from U.S.A. or is it Japanese market. this forum is almost all American market cars. the other market cars are often different from ours.
Old 10-14-15, 01:13 AM
LS430670
10th Gear
LS430670's Avatar
King I'm not sure on the tranny flush.
Jffgry the Lexus' that we have here on Saipan are normally shipped in from Guam since the dealers are one in the same. Atkins Kroll Guam and Atkins Kroll Saipan.
How can we tell if it's the lifetime model or the 5 speed model?
Old 10-14-15, 02:29 PM
KING
KING's Avatar
Your car is an '03, so it's definitely the 5 speed model tranny with a dip stick under the hood.
The 6 speed was introduced in the '04-'06 versions of the 430.
Old 10-14-15, 02:32 PM
LS430670
10th Gear
LS430670's Avatar
Ill try the tranny flush first and PRAY that it works.
Thank you
Old 02-29-16, 12:59 PM
ancdmd
ancdmd's Avatar
Whatever happened with your transmission? I'm having the same issue, been told by a Lexus dealer and two indy shops that it's "morning sickness"... transmission is slipping and needs to be replaced! Ugh
Old 02-29-16, 01:45 PM
LS430inDE.
LS430inDE.'s Avatar
How many miles on the ticker? What's the service history of the tranny?
Old 02-29-16, 02:44 PM
ancdmd
ancdmd's Avatar
177k miles, 2002, I've done full 10-qt fluid exchanges every 30-40k miles, not just pan drain-and-fills.
gravel
08-15-22 08:44 AM
Lex223
11-18-16 03:14 PM
NitrousNik
10-10-10 10:03 PM
Grisik
02-05-10 12:45 PM
dannieboiz
08-02-04 09:14 AM
Quick Reply: 03 LS430 slipping in reverse
