AC Swing not working
Buying an 04 and the Swing function of the AC only works on the right set of vents. The left just doesn't move. I've tried the search function but can't come up with anything. Help.
Sounds like a little arm the connects to the vent might be broken. You'll need to pull it off to inspect it. While it's off spray a little dry lube on the joints. This happens when some bright bulb decides to hold the vent stationary to force it to stop moving - or move a different way.
I love my oscillating vents! They had to replace the motor twice under my CPO warranty because of small noises. You probably should just take it to the dealer. I wouldnt mess around with anything so small with a motor.
when I have a passenger, the vents swing from side to side but when I am alone they only go center, then back on me. not a big fan of air blowing on me so I turn it off
jaytone
05-26-10 05:18 AM
