Sweet Smell - Possibly Heater Core?
Old 11-30-15, 05:05 AM
LS430Lexus
LS430Lexus's Avatar
Default Sweet Smell - Possibly Heater Core?
In the last few weeks, I have noticed the sweet odor of coolant at start-up. It only occurs one of every four times or so and goes away very quickly. It could be a leak in the heater core. I don't recall hearing about anyone else with this issue. Has anyone had to replace a heater core, hoses or other parts to solve this? Suggestions are appreciated, thank you.
Old 11-30-15, 08:58 AM
jimbosr1
jimbosr1's Avatar
i would give the engine bay a good inspection for dried coolant,pink chalky areas first then go from there.
Old 11-30-15, 09:51 AM
bmore430
bmore430's Avatar
Don't see many people talking of heater core issues with these cars. I would check your radiator, hoses etc under the hood first. Let car run and get up under dash and see if you can smell or feel for any leaks.
Old 11-30-15, 01:06 PM
Bocatrip
Bocatrip's Avatar
The red coolant is nasty stuff when it leaks so you should find it if inside. I would also check the radiator seams and hoses first as well as pressurizing the system to check for leaks.
Old 12-01-15, 05:02 PM
Arcturus
Arcturus's Avatar
+1 check the rad and reservoir. If no evidence get it pressure tested. You can also put UV dye in the coolant and use a black light to trace the leak. Dye is available off Amazon.
BillBrasky
IS - 1st Gen (2001-2005)
12-04-17 09:15 PM
salimshah
02-21-16 02:26 PM
lexus-is2
07-10-14 12:47 PM
SGVARISTO
GS - 1st Gen (1993-1997)
17
10-15-13 09:07 PM
ekrebs
Performance & Maintenance
11-30-08 03:01 AM
Quick Reply: Sweet Smell - Possibly Heater Core?
