Another LS430 Rear Camber Out of Spec
2004 LS430 (All OEM stock Rear suspension)
Rear: Right Camber is -2.1 (range is -1.8 to -0.8)
Rear Left Camber is -1.0
Goodyear Dealer (latest Hunter laser equipment) tells me that the rear Lateral arm needs to be replaced. Looking at the TIS 27-26 rear suspension report, there are two rear arms. One arm has the height control sensor attached to it and comes in 3 lengths. Is this the arm that needs to be changed to correct the camber?
Since the left side is within spec with stock components, I assume that correct camber can be achieved with OEM stock parts.
Should I order a 441.5 mm length or 446.5mm or 451.5 mm length arm in order to get within spec
Lexus Part Numbers:
RR Lateral Arm - Right
441.5 mm: 4873050080
446.5 mm: 4874050040
451.5 mm: 4873050090
Thank You
Lexus Part Numbers:
Thank You
Can anybody confirm that the OEM stock arm is 446.5mm in length? If so, I am assuming I would need to go with the shorter 441.5mm arm in order to lower the negative camber number from -2.1 to within spec of -1.8 to -0.8?
Could this over compensate and place me with positive camber and out of spec in that direction?
I hope this helps in any way.
When I had my alignment done, I was told that the rear had some camber and the stock arm couldn't compensate for that extra camber, and confirming what your mechanic had to say, they also told me that I needed an aftermarket arm that was shorter in length.
I guess they should figure out how much length is needed in order to return the wheels to factory specs.
I never got the aftermarket arm. #camber_life haha, just wasn't too worried about it. I like the way it looks, especially that it's really not too much camber at all.
Slight negative rear camber is not unusual on LS. I have slight negative camber on my '01. However, the car steers straight at 80 mph, and I rotate every 5,000 with oil / filter change. Are you changing the arm simply to make it within "spec" or is the slightly out of spec camber causing something that you see in tire wear or feel when driving? Even the most sophisticated alignment machines have to be calibrated. The alignment machine can be slightly off giving a reading that is within a margin of error. For example, if you had the alignment checked at a Lexus dealer, the alignment readings would not be exactly the same as the readings given at Goodyear.
Thanks for sharing your results, grunner.
*My concern with alignment calibration is the possibility that actual readings could be -0.4 off of true/actual, which would mean that you are, in fact, within spec. What were the front wheel readings before adjustment? Were the front wheels showing excess negative camber?
**Also, how do you know you need a different size arm than the OEM? The bushings in the original OEM arm could be worn causing the slight excess negative camber, so you would need an OEM size arm replacement.
The difference in each rear arm is 5 mm = 1/2 cm (not insignificant). Is there a camber-equivalent number of degrees associated with a 5 mm change in the arm length? In other words, how many degrees does a 5 mm change in arm length equal? Ideally, you'd want to match the camber reading on the left rear (-1.0), which is only 1.3 degrees away from current. (As you observed, you don't want to cause positive camber.)
Crawled under the car which is slightly lifted by my 2 x 12" stacked board design that gives me 3.5" lift. Anyhow, the arm is a 446.5mm and that was OEM to the car. After reading the comments here, and online, I decided to order the 446.5mm length and cancel the 441.5mm Since the left side is also 446.5 I don't see any reason to mess with differing arm lengths.
Installed the RR Lateral Arm - Right 446.5 mm: 4874050040
Brought it back to Goodyear and it barely changed the camber setting by 1/10th but still left it out of spec. That's what I get for listening to a Goodyear Tech who assured me that replacing the arm would bring it back into spec.
The arm is very easy to replace and took about 30 minutes once jacked and on stands. I will probably go to Lexus and have the alignment done correctly as they left the steering wheel at about 11:30 when driving straight. Had to bring it back for a proper alignment. Ridiculous!
Hopefully another alignment place can figure it out for you. If not, then as Tom was saying, it shouldn't really be a serious issue, so hopefully that makes you feel better about all of this.
Turned into such an adventure and I posted it as a warning to stick with the dealer on alignment related issues.
