MPG readout
Old 12-13-15, 11:24 AM
beneteau
beneteau's Avatar
Default MPG readout
What controls the MPG (average/current) readout on the dashboard? The one in my wife's LS is stuck and doesn't change readings.
Old 12-13-15, 11:46 AM
Lavrishevo
Lavrishevo's Avatar
Did you try to reset it via the steering wheel. Hold reset for about 5 seconds. If that does not work pull the negative on the battery for 10 seconds and then re-attach. The mpg is calculated by fuel consumption I am sure.
Old 12-13-15, 11:50 AM
Tom57
Tom57's Avatar
Average is calculated over all mileage. Current is measured after each fill-up of gas. Press the "Reset" button (on the inner right side of steering wheel) to clear the stored data. Or, disconnect the battery for 5 minutes for a soft reset of the settings. (Disconnecting battery loses radio station presets and some saved Navigation points.)
Old 12-14-15, 06:03 AM
Lavrishevo
Lavrishevo's Avatar
If you disconnect for 10 seconds to a min or so it does reset but you don't loose radio stations. At least in my car. As far as an nav presets go I'm not sure as I don't use them but I never loose radio stations.
Ericspyder
08-31-18 07:18 AM
lostinthew
08-06-13 06:54 AM
xRYD3Rx
05-20-13 03:28 PM
Chow
04-29-13 03:08 PM
khark
RX - 1st Gen (1999-2003)
04-28-07 02:49 PM
Quick Reply: MPG readout
