2004 LS430 drivers door lock inoperative
Old 12-27-15, 01:32 PM
Skydiver
Skydiver's Avatar
Exclamation 2004 LS430 drivers door lock inoperative
Hi All.
Just experienced one of the first things to go wrong with my LS, the drivers door lock died (not bad for 163k). I looked for the part in various places on the internet (eBay, amazon etc) and saw some motors "Car Door Lock Actuator for Mabuchi Motor Repair Lexus Toyota NEW" for sale, but none matched the LS430, nor could I find any YouTube videos showing one specifically for an LS replacement. Not sure if these even apply to the LS or does one have to order the entire assembly. Has anyone else had a similar issue and knows the best course of action?
Old 12-27-15, 02:02 PM
Tom57
Tom57's Avatar
Have you checked this thread? > https://www.clublexus.com/forums/ls-...-tutorial.html
EDIT: The OEM Mabuchi "D" shaft motor is available:
Central Door Lock Actuator Motor FC-280PC-22125 FLAT SHAFT, D Spindle, Power Locking Repair Engine - Motor Accessories - Amazon.com Central Door Lock Actuator Motor FC-280PC-22125 FLAT SHAFT, D Spindle, Power Locking Repair Engine - Motor Accessories - Amazon.com
Old 12-27-15, 04:18 PM
lexman52
lexman52's Avatar
U need the D shaft. U can get it on amazon.
Old 12-27-15, 04:22 PM
lexman52
lexman52's Avatar
The one in your pic. is the wrong one. U need a short D
shaft
10mm-Flat-Shaft-FC-280PC-22125-Door-Lock-Motor-Repair-Actuator-Toyota-Lexus-D
I had a body shop put it in. $90.installed
Old 12-28-15, 04:58 PM
Skydiver
Skydiver's Avatar
Smile Thanks guys!
Hey, really appreciate the help guys, thank you!!
Jeff
Old 12-28-15, 07:30 PM
Tom57
Tom57's Avatar
shaft.
Corrected edit above to example of 10 mm shaft motor.
Old 12-29-15, 03:44 AM
lexman52
lexman52's Avatar
Skydiver i would buy 2 or 3 so u have backups. I have 5 for me and anyone i know who needs one.
Old 12-29-15, 04:43 AM
Lavrishevo
Lavrishevo's Avatar
These motors also power the folding mirrors.
Old 01-20-16, 03:34 PM
Skydiver
Skydiver's Avatar
Hi Everyone,
Just repaired my '04 LS430 drivers door lock actuator yesterday, and have some note tips for those about to dive in:
1) Do remove the key lock via the access port (black plug cover) it's easy and makes life simpler
2) Remove the large 6" x 5" black plastic piece (two silver bolts and sticky tape..just pull it) attached to the inside of the door behind the clear plastic sheet.
3) Remove both bolts for the window guide (it's impossible without doing this)
4) Be careful when taking off the door latch rod plastic retainer clip, easy to break it.
5) When replacing the actual motor I used alcohol to clean all all the grease from the actuator module or the glue would not stick. I used JB (quik) weld to glue it back on (JB weld is the only thing I have found that will permanently glue plastic)...knowing that it will not come off...ever.
6) When reassembling use a box under the inside door panel to relieve the stress on the electrical connectors.
Good luck all, time invested was well worth the money saved!
Old 01-20-16, 03:37 PM
Skydiver
Skydiver's Avatar
Thanks for that tip, I actually ordered the wrong motors (long shaft round) and will keep them for the mirrors.
Old 01-21-16, 07:22 AM
jpv7774
jpv7774's Avatar
Nice job skydiver....congrats. Just a note....they do make a motor w round shaft that will work.....u just have to take a few seconds to file it down to a D shaft.
jimdwright
08-05-23 05:05 PM
bnguyenz
02-19-23 07:45 PM
bagito
10-08-18 04:44 PM
Arcturus
03-14-18 11:47 AM
jamesrawr
06-05-13 08:17 AM
Quick Reply: 2004 LS430 drivers door lock inoperative
