Helo guys please help i have a ls430 2004 while driving i was surprised to see the check engine light followed by check VSC ! On the dashboard .used my scanner obd 2 and got the code P0758 could you please guide me where is the shift solenoid valve no 2 circuit located could you please guide on how to change it as i tried to find out but ended up with nothing. The gear is not shifting more than the 4th speed
Please advice leaders
Yes, now reset the check engine light using a OBDII reader or go to an autopart store to have someone behind the counter do it for you. See if the check light comes back. If it does find out the error code and go from there.
The gear hits hard when shifted to drive and it sticks to 5 gear knowing it's a 6 speed still shows thee same error I think it's an issue. With the wiring or as it still shows the same error
Hi team got an error notifying my solenoid isnt working with a check vsc i tried changing full solinoids and ended up exchanging the full transmition, now after changing the transmission im having a slight vibration if i drive it slowly @40-50 km/h . Changed the shaft still it continues on . can any one guide on whats the issue
