Does Mark Levinson System Support AAC music files?
I want to buy the Viastech ipod integration for my LS.
Does anyone know if i will have any problems laying AAC music files through ipod to Viastech ipod on the Mark Levinson audio system??
I have the older SLi unit in the LS430 and it sounds fantastic; but it's picky with the quality of the files. 256K or higher will sound markedly better than the standard 128K.
The ML is that good.
Cheers!
Anything that the iPod will play through your headphones will play through the VAIStech box.
Forget 128K, 256K, the MP3 format, and any other lossy compression algorithms - they all sound terrible when you have a system as good as the Mark Levinson. It's easy enough nowadays to find everything in FLAC, but since the iPod doesn't play FLAC files, just convert FLAC to WAV (FLAC Front End 1.7 is easy to use), then load the WAV files to the iPod.
If you are short on space and have time for the extra step, convert the WAV to AAC to apply the only lossless compression that the iPod can play. I personally don't bother since I have plenty of space so it's a useless extra step for me.
I suspect most people who complain about the ML speakers not sounding good are not using store-bought CDs in the factory CD player or are not using lossless music files through a direct integration kit. The ML system incredibly clear and accurate at all frequency ranges and volume levels. The subwoofer doesn't echo or hit harder than it should (although some people are accustomed to and prefer such untuned systems).
All speakers reproduce sound pretty much exactly as it was recorded in the studio. But low quality music input equals low quality music output, so feed your system with the highest quality input possible.
Another thing would be the format of the USB. Make sure it's formatted to FAT32 so that it can be read by the Vaistech.
I have the MML as well, but I just received my car from Central Pine yesterday, so I haven't had the chance to install mine and play around with it.
So check the user manual for the correct file naming.
But the idea of having a mobile USB that you can carry to your laptop, fill and update with music, and then bring it back to your car with you, plug it in and forget about it; is also a really nice feature to have.
Maybe you have to put them in a specifically named file, "Music" for example.
I have 3 VaisTech MMLs and love the sound quality - but the recorded input must be high quality lest the output will be low quality. The ability to stream music, podcasts, radio, etc. and operate it through the existing audio controls is seamless.
I think the USB protocol would work with an old phone as well; if you have an old phone with removable storage it might be worth a try.
vbb
01-24-13 12:53 PM
mysel420
GX - 1st Gen (2003-2009)
06-08-10 09:02 AM
