Bad camera or bad camera ECU?
Old 03-01-16 | 07:57 PM
mrboca's Avatar
mrboca
Has anything changed in the camera display status ? Completely black now ? sometimes see image with lines still ? Maybe some software / firmware issue with the video circuit. Have you tried disconnecting the battery and reconnecting after a minute or so ?
Old 03-01-16 | 08:28 PM
RRocket's Avatar
RRocket
Originally Posted by rkw77080
Which year model is your LS430?
Please take a look at the 2 "Problem Symptoms Tables" below and see if your symptom is listed. This will help narrow where we need to troubleshoot.
Mine is:
"When shift lever is in "R", rear view image is not displayed (Screen is black)"
Suspected area: 1) Display signal circuit (Television Camera Assembly-Television Camera ECU)
2) Television Camera assembly
3) Television Camera ECU
I had already suspected 2 or 3 as I said in initial post.
Old 03-01-16 | 08:30 PM
RRocket's Avatar
RRocket
Nothing has changed with car. Worked one day and not the next.
Old 03-01-16 | 09:58 PM
mrboca's Avatar
mrboca
Is your Navigation working ?
Old 03-02-16 | 05:52 AM
mrboca's Avatar
mrboca
If your navigation system is not also working (no display) I would check the 7.5 amp fuse for the TV ECU located at the fusebox in left side of the trunk. The navigation ECU signaling go through the Camera / TV ECU. This supplies 12V to the unit.
Old 03-02-16 | 04:43 PM
RRocket's Avatar
RRocket
Navigation works just fine.
Old 03-02-16 | 09:10 PM
mrboca's Avatar
mrboca
Have you tried to check if the system detects the camera using the System Check Mode ?
Old 03-02-16 | 10:54 PM
RRocket's Avatar
RRocket
No I have not! How do I do that??
Old 03-03-16 | 08:27 AM
mrboca's Avatar
mrboca
Try
https://www.clublexus.com/forums/att...menu-part1.pdf
Open the pdf file in the link, and follwo the instructions. You have not mentioned what year your car is....
Old 03-03-16 | 05:13 PM
RRocket's Avatar
RRocket
Try
Thanks!
And yes, that's an important detail I omitted. It's a 2004 UL
Old 03-03-16 | 05:55 PM
RRocket's Avatar
RRocket
OK...I did the System Check Mode...and Camera came up with "CHEK" in orange.
So is that proof positive that it's the camera that's at fault?
Old 03-03-16 | 06:34 PM
mrboca's Avatar
mrboca
Can you get into diagnosis mode ? While in system check screen with orange check for camera, press the menu on the upper right to get into diagnosis mode. There is a camera test entry you can select.
Old 03-03-16 | 06:51 PM
RRocket's Avatar
RRocket
Yes, I did that. It essentially just turns the camera "ON". And of course, the screen was just black..though I did have a flicker or two.
Old 03-03-16 | 08:08 PM
mrboca's Avatar
mrboca
I guess than the problem lies with the camera and / or the cabling / connectors. If you can remove the connector at the camera side (4 pins) you could take some voltage measurements on the connector from the ECU wire harness. You can check if the 12 V (or may be 6V) is received at the socket for the camera. I believe the pinouts were posted in earlier responses.
RRocket
06-14-20 10:20 PM
Tguillama
GX - 1st Gen (2003-2009)
06-19-17 09:27 PM
RookieLEX
ES - 5th Gen (2007-2012)
06-29-16 03:43 PM
Rowdiggty
04-18-14 08:14 AM
