Change Crank/Cam Seals When Changing Timing Belt?
I'm not good at forums, but need help. Had Cam shaft seal replaced recently, now I'm told the valve gasket cover is leaking. It was replaced 6 yrs ago, 2013, and we put on around 10K a year. Didn't expect to need to redo again this soon. Might they have messed it up when doing the Cam Shaft seal job?
