2000-2003 RPM at speed
Dear Gents,
I had the car fully refurbished for a lot of money, ATF change included.
Since then I am not sure if the transmission changes to 5th gear.
Could you please advise what RPM you have at different speeds after speed is stabilized and transmission is at required gear?
In normal mode, not PWR or snow.
Like what is your RPM at 110 mph (~180km/h)?
Thank you for the info.
There is no indicator in LS430 between 2000 and 2003 and mine is from 2001
To test 5th gear as it definitely should shift to 5th gear at 110mph.
Wouldn't you think? As I have already written, the car was refurbished and I wanted to make a thorough test and that was the test drive.
Anyway I don't think your post takes us to the right direction.
