Mercedes Rims on my 04 LS430
hi friends. i am new to this modification but i am interested to make some change to my 04 ls430 but i am not sure which precautions should i take before i start. i am planning to install mercedes s500 amg rims on my LS430. the rim size of mercedes is 20". can anyone help me in this ? is it fine if i change ? or what changes should i made before i install this one? do i need to lift up my car when installed this one ?
thank you all for the help.
I don't think they will fit. Ls430 lug pattern is 5x114 and Mercedes is 5x120. If you really really want them to fit, you will need an adapter which runs about 100/pair. But they will cause to push the wheels out (maybe 20-30mm). Not sure of how wide or offset the the Mercedes wheels but they might end up rubbing
If you are dead set on running those AMG wheels you can get them redrilled or use wobble bolts. They are 5x112 which is only a few milimeters off from the ls430 pattern (5x114.3). I have even had wheels drilled from 5x120 (BMW) to 5x114.3. Reputable wheel/machine shops in the Los Angeles area charge about $100-150 for all four. Typically, the job is done by slightly widening the holes and pressing in inserts.
What about this as an alternate?
http://www.tirerack.com/wheels/Wheel...4&autoModClar=
It's close to the MB wheel, and it should fit the LS
Super Moderator
In past times the VIP car crowd installed MB wheels, late 90's early 2000's. This has fallen out of fashion these days though we do see BMW wheels from time to time. Wheels with the correct bolt spacing and hub bore can be bought these days so installing MB wheels is an added expense.
Carlsson has wheel applications for Lexus:
http://carlsson.co.jp/lexus_products/
One of my favorite old school wheels on the LS400
ohh... greattt ...... thank you everyone ... thanks alot for this great information. i am really thankful to everyone who commented above. because this is my first post and i got many things new which i didnt knew. i will check now how i can fit these rims because these are the rims which i love
spender
Wheels, Tires & Brakes Forum
07-08-07 04:36 PM
