Clicking when turning
Old 04-15-16, 04:43 PM
Jbthompson
Jbthompson's Avatar
Default Clicking when turning
Hi everyone. I replaced my inner and outer tie rods a few months ago. Every since, when turning the wheel to the far left I am hearing a metallic clicking sound. It sounds like a popping clicking sound. Took the wheel off to examine and it looks like it's coming from the steering rack past the inner tie rod. Any ideas? Should I grease up the steering rack?
Old 04-15-16, 04:45 PM
yoitskenn
yoitskenn's Avatar
Check your axles.
Old 04-16-16, 07:40 PM
Jbthompson
Jbthompson's Avatar
Originally Posted by yoitskenn
Check your axles.
Interesting. What are the signs of a bad axle? Seems odd at 117k.
Old 04-16-16, 07:50 PM
yoitskenn
yoitskenn's Avatar
Clicking and popping
Old 04-17-16, 10:56 AM
911LE
911LE's Avatar
If the noise is coming from the front it is definitely not an axle. The LS430 is not front wheel drive.
Old 04-17-16, 12:05 PM
Jbthompson
Jbthompson's Avatar
Definitely front driver side. It sounds as though it's coming from where the inner tie rod connects to the rack.
Old 04-17-16, 12:47 PM
yoitskenn
yoitskenn's Avatar
Ball joints usually click and pop. Mainly over bumps though
Old 04-22-16, 03:14 PM
Jbthompson
Jbthompson's Avatar
Found out that some bolts on my tie rods weren't tight enough (even though I used a torque wrench). My mechanic tightened everything and noise is gone. Best $45 bucks I've spent.
kmy
Suspension and Brakes
16
06-06-12 07:59 PM
Vadim540i
SC- 1st Gen (1992-2000)
05-12-10 06:02 PM
scfocus
08-19-09 07:42 PM
Verge
GS - 1st Gen (1993-1997)
10-13-08 09:49 AM
Quick Reply: Clicking when turning
