Need longer studs, where to buy?
I need longer studs for my Iforged wheels. They hit the brake caliper, with a 3mm spacer they rest on the caliper so I tried staking two 3mm and it was fine so a 5mm spacer is perfect however I only get 5 turns with a 3mm so know I won't get anywhere near enough turns on the studs with a 5mm spacer. Where can I locate longer studs? 5mm longer than stock would be fine, 10mm would be perfect.
I have intergrated lugs/spacers on my Lexus LX450 but that is because they spacers are 1.5 inches, im pretty sure 5mm is way too thin to have studs on the...I think I saw 15 is the lowest number on those....they do sell spacers along with longer studs, i may do that
4play4dr
Suspension and Brakes
21
07-07-15 03:20 PM
Rich27
Wheels, Tires & Brakes Forum
03-31-09 11:00 AM
