Several trouble lights came on
Driving along at 30 mph when there was a beep and the lights that you see in the picture came on. Car runs great. No switches were touched. Turn off and back on - still there. Car goes in to the shop tomorrow. First thought is a bad connection in a harness plug caused by water when they cleaned the engine but maybe not. Any suggestions?
Keith
Keith
My 2001 Base with 222,000 did the same thing a month or so ago... With the warning lights on the car ran fine, but i did keep my foot out of it until the issue was corrected...
Check Engine Codes were: PO1346 V V T Sensor/Camshaft Position Sensor Circuit Range/Performance Problem Bank 1 and PO1349 V V T Malfunction.
In reading, it led me to the oil control valves, I took both out and tested with 12 volts, the LEFT side was hardly working and the right was nice and strong... New part cost $130 or so at the dealer and installed myself. With new part in hand from star to finish it took 10 minutes or so to install.
Hope this help and let us know what it was....
Steve
Steve
And the answer is...
Code shows emissions out of specs. Sensor downstream of catalytic converter out of range. Possibly caused by the Chevron TECHRON® Concentrate Plus injector cleaner I put in tank. If sensor is close to limit it can push it over. Reset code and keep driving to see if it comes back.
Keith
Keith
Well, at least you know what NOT to put in the tank from now on...
