Ls430 daily driver project
What's up guys. I just recently picked up a 2001 ls430 ultra luxury. It has 124k, and has 6 pages of service history at a Lexus dealer up until 110k. I got the car so I didn't have to continue to drive my Audi every day and break things. So far I am loving the car. Super comfortable, quick enough for what it is, and just overall an awesome car to drive.
So far I have just done some basic maintenance, the serp belt was in pretty bad shape so I replaced that, changed the oil and filter, and I just got some denso iridium plugs to put in. It looks like everything major has been done, but are there any other preventative maintenance things I should do immediately? I'm used to euro cars, and the main reason I got the ls is for the reliability.
Once I get it all up to par maintenance wise, I'm going to slowly start the mods. My Audi is super modded, so I plan on keeping the LS pretty mild, as it is my daily. I'm planning on 20s, the air controller, and maybe the youzeland kit if it's not low enough.
I do have some questions about the air, as this is my first car with airride. Can I upgrade the oem compressor and add in a small tank to speed up the air up/down times, or is it the airlines that cause most of the restriction?
I'm looking forward to getting into customizing the LS, but it's going to be slowly so I can finish my Audi first.
<br > <br >
<br > <br >
Welcome to the club, fl. You're question may have been discussed on here already, so if you search, you may find what you are seeking. Sorry I'm no help, but again, welcome aboard!
Are you going to 20 inch rims for aesthetics or to improve handling?
Most people agree that anything larger than a 17" rim on an ls430 has undesirable noise / ride quality / tire cost trade-offs.
The car has double wishbone suspension all around so they don't take big rims / low profile tires like the lower end german cars with their macphearson struts. If you're looking for a better handling car, consider 17/18 inch rims and replace your air suspension with sport suspension struts and lowering springs.
Also, Japanese cars use the fluids sacrificially. Consider replacing the differential fluid, transmission fluid , power steering fluid, and brake fluid if they haven't been replaced in the last 30k miles.
I want to do 20s for aesthetics. Maybe 19s, I think anything smaller looks tiny if the car is low. I'm love how the car handles, but I'm willing to compromise that a bit so it will look how I want. I'm going to be doing some more performance stuff on the Audi, so the LS is pretty much just my daily. I just want it to look good and drive comfortably
Would it air out low enough it tuck 19s a bit with the youzealand pro kit? I understand the ride will be worse, I'm fine with that. Im sure it will still be comfortable, I have 32k Spring rates on my Audi so I'm used to extremely stiff suspension.
Kinda forgot I made this thread, I haven't done much besides some maintenance and just enjoying the car. I shortened the front sensors and adjusted the rears to go a bit lower.
I also had some time to test fit my front lxz (19x10.5et5) and my friends Cerberus (19x10.5et18). I really like how the Cerberus fit, so I'll probably run specs similar to that when I get wheels. Hanging with some friends. My friend just bought that super clean ls400.<br ><br > Sensors adjusted <br ><br > Cerberus test fit <br ><br >
Bob04
05-09-20 08:38 PM
