Transmission Pan/Filter Torque Specs
Hi, I am going to be dropping my pan and replacing the trans filter on my 2002 LS430.
Does anyone know what the correct LEXUS torque specs are for:
1. Transmission Drain Plug
2. Transmission Pan Bolts
3. Transmission Filter
Thanks in advance!
Thanks in advance!
Perfect, thanks!
Do you know if the factory uses RTV to seal the pan or whether they use a gasket?
As much as I want to drop the pan, clean the magnets and change the filter, I really don't feel like having to clean RTV off the pan and case!
I don't think the pan's ever been dropped so I assume it's sealed with whatever the factory used.
Perfect, thanks!
The .pdf posted above shows the placement and quantity (bead size) required on the last page. Toyota calls rtv fipg (form in place gasket). I use Permatex ultra black and have had zero issues.
Sometimes RTV can be a royal pain to remove. Although all the transmission pans I've dropped had cork and/or rubber gaskets (very easy to remove), I've fought my share of battles cleaning up RTV when replacing water pumps.
Additionally, I have been doing regular flushes (using the cooler line) and the trans shifts great. Part of the hesitation is the 'If it ain't broke, don't fix it" mentality about dropping the pan.
The only thing pushing me is I just dropped the pan and replaced the filter on my 2007 Corolla with 117,000 miles. It was the first filter change and the filter definitely had some 'grit' on the mesh. No where near clogged and the magnets were pretty well coated in the fine greyish powder you always see. As the LS430 has 181,000 miles and the pan's never been dropped, I almost feel compelled to drop it, clean the pan/magnets and change the filter.
I am looking at a Beck/Arnley filter with a rubber gasket. How do you guys feel about using the rubber gasket and not messing with RTV?
If you feel compelled to drop the pan go ahead and do it. I think Toyota doesn't recommend it as you run the risk of contamination when opening a closed system. One miniscule piece of rtv or dirt introduced accidently while cleaning the case surface or while the pan is off can wreak havoc on any of a number of small oil passages inside the trans.
I would recommend using rtv to reseal it and not the gasket even if it comes with the filter. The rtv essentially glues the pan on with less chances for a leak. The pan is actually designed to use rtv and not a gasket. The mating surface has valleys stamped into it which promote a better seal when the rtv is applied as per the factory service manual. Gaskets can cause issues from being under or over tightened, they can dry out and shrink, or they can swell over time from additives in the oil. Almost all of our cars need valve cover gaskets replaced at some time but oil and trans pan leaks are pretty uncommon. Trust Toyota. If they thought the tranny pan would be better off with a gasket they would have used one.
That would be my advice, to just leave well enough alone.
I just see very little upside to dropping the pan considering you've been regularly changing the fluid. Just seems like a needless headache in my opinion, but I know we all suffer from wanting to be meticulous about maintenance on these cars.
Some sludge, magnets not bad although one short.
pan was factory sealed. One hour to remove rtv.
put new screen and used gasket, plastic switch plate for scraper, some hook Velcro to rub out pan flange. Did not scratch coating on pan, it will rust.
the drain is convex at plug explains sludge.
the pan has been drained a few times.
pan drain a650e 3 quarts a little more on removal
so, 4. I'll flush today after refilling. Driver side return on radiator. Trying segmented bucket pour in equal to pump out. Hope it helps, good day.
pparziale
08-13-14 10:11 PM
RNDRX
03-23-09 01:39 PM
