Air suspension
Air suspension
Can anyone else hear the compressor in the car? Also, does anyone else's run at times other than after first start of the day or after getting off the interstate? I've noticed mine running sporadically at times other than the two I mentioned. Will I get any warning if I'm headed for suspension failure or issue? Also, do the air bags in the struts simply absorb the bumps and there are also springs? Or... If the system fails will the car be grounded like those Lincolns you see from time to time sitting on the frame from air suspension failure- it's worried me sick as its my only vehicle and I'm stretched to the penny on budget- I'm sure there's talk about this somewhere but I've searched and don't see it, also I'm learning this garage talk app- my apologies if the info I seek is redundant.
2001 Ls430 UL
2001 Ls430 UL
The air bags on air struts act like springs in standard struts. Do you think it's safe to drive a car without springs? If the air bag blows, especially the front one, your car is grounded. Yeah, you can still drive the car but not without significant damage to the vehicle. I converted mine to struts/springs and now 100% worry-free and never looked back.
Don't get overly worried. A lot of people aren't even aware that their air shocks are starting to fail. The dealer will tell you when there is an oil leak streaking down the shock. The air shocks are not large air bags like the older Lincoln/Cadillacs. I don't think you're going to be riding on the frame. I've had my air shocks replaced and the only problem was the cost.
Thank you Jayclapp - can I inspect the shock in my driveway for this oil on the shock you speak of? Other than my air pump running intermittently at times it didn't used too I've noticed nothing else. If they fail how will the car remain up off the ground
FYI:
1. The airbag that blew on mine did show any oil leakage and the bag that had small oil leak rode just fine. The source of the oil leak is from the strut and not the airbag, but since the airbag encloses the strut seals, oil leakage is visible when there is also an airbag leakage.
2. Turning the wheel and moving the car a few yards onto my driveway was enough for the wheel/tire with the blown airbag to rub the fender and nearly ripped of the fender trim off. Can't imagine what would happen if had to drive the car down the road at high speed for an extended distance.
ok, so I've seen lots of posts about the air bags on the GX, either leaking problems, sensor problems, leveling problems... I replaced an air bag about 8 months ago as it leaked so badly it was riding on the bottom. I was warned the other side could go out soon but thought it's not gonna cost any more or less to fix it on that side if it does, so I left it alone. System has been working flawlessly since. Until this week, the system isn't working at all. No pump, no air, no leak, its as if its not turning on. Anyone suggest something I can do to reset or test what the problem is? No dash lights providing error codes. It's riding on the bump stops so it really can't be driven right now. I've checked all connections including fuse and relay...nothing found.
2001 Ls430 UL
2001 Ls430 UL
BNR34
11-21-23 07:35 PM
