Mechanic did coolant exchange like this-
If I were even able to obtain this antifreeze tester here in florida, theoretically I should be able to check to see what percentage of antifreeze to water was used (Toyota Red was used) by seeing how low the car is protected to correct? What temp would correlate to a true 50% mixture? -31F?
It's probably going to be hard to nail down to an exact %, but if there is very little freeze protection, its a good bet its really diluted.
I would argue getting an exact 50/50 mixture is not some make or break situation. The higher the water to antifreeze ratio, the cooler it will run. The more antifreeze to water, the better the freeze protection. The ratio would have to be drastically off or you live in the ice tundra for there to be an issue in my opinion.
If you think it's too diluted, you could always drain some off and put more concentrated antifreeze in. Would only take a few minutes, just make sure the car has completely cooled down first.
Just picked up a Prestone antifreeze/coolant tester at walmart for 3 bucks. Says on label it works for all Ethylene Glycol coolants including Prestone, GM, Dex-cool, 5/150 extended life antifreeze/coolant. The Toyota Red is based on Ethlene Glycol. Shouldn't this tester give me an "idea" of what percentage of water to red coolant by the boiling point listed? How far off could it be?
For $3, take different known samples of antifreeze (red toyo) and compare your preparations to the tester.
If your 100, 50/50, and straight water can be identified by the tester, then Great. If not, learning experience only cost ya $3.
Its the add pack that screws around the most. In the past those have not been accurate for me personally.
ThumperPup
ES - 5th Gen (2007-2012)
09-24-13 08:56 PM
