Ls430 idle noise
Ls430 idle noise
Hi!
I have a pretty noise during idle, sounds lika whining almost like a fan or belt noise. It's pretty loud from outside The car and you can hear it in The cabin, it doesnt go away and goes up with revs.
attaching a youtube link.
thanks for all The help.
Hi!
Ls430 idle - YouTube
dont know in miles but is is 197000km
the light is an faultcode for oxygen sensor, going to get that fixed!
alright! Gonna check those out after work tomorrow!
Having the same problem it’s giving me a feeling that it might be the computer because I’m get camshaft position sensor both and both catalytic converter sensors and a random misfire but it don’t feel like it’s misfiring nor preforms like a misfire drives good just a little confused
Remove the serpentine belt, start it up, and see if the noise goes away. If it does, spin all the bearings and idlers in the serp belt path to see which one makes noise or is otherwise not completely smooth and replace. The belt might also be bad - slipping.
uberfuzz (09-02-23)
I’m getting the same thing with my ls430 a loud high pitch noise only at idle
