Best place to fix Nav unit
Looks like mine is on the way out, saw a post somewhere where someone had a place that fixes these. Anyone know?
Thanks
Thanks
You may want to consider replacing the Nav player. See >
https://www.clublexus.com/forums/ls-3...-dvd-disk.html
https://www.clublexus.com/forums/ls-3...v-upgrade.html
Here is my problem,
Checked out the car on a Monday, car only had 68K miles on it, everything was great with the exception of what I thought were blown speakers. Part of the deal was for the dealer to replace the battery and pick it up the next day. Got the car home drove it for a while and the Multi Function Display started displaying these warnings. Thought that when the replaced the battery maybe they shorted something. I checked the service records and at some point the back up camera was replaced.
1 External System Not Connected
2 Check the connection of the air conditioner
3 Check the system.
4 audio off.
This is an intermittent problem, sometimes everything will work upon start up sometimes it will just quit and then come back. When it's working, the NAV, Climate and audio all seem to function properly. Then, poof, it goes away along with the clock above the unit.The AC still works but it stays on all the time. I've checked all of the fuses and they seem good.
I found a clip on YouTube on how to get the diagnostics through the head unit and run a system check when the HU is working.
At first everything checked out but it did say to check the HU, also says this code 48B NCON and another something NCON which I assume means not connected.
Can't find these codes referenced anywhere.
After researching here, I've come to these possible issues:
1 Loose connection somewhere, I plan to pull the head unit out and check all of the connections, some posts say that there is a fuse on the back side of the head unit itself.
2 The infamous ML amp issue, ill do the same as above. I'd hate to replace it if its not bad.
3 The Head Unit is bad. ( At least this is what the dealer told me yesterday and at a cost of $1800 for a re-manufactured unit, I said I'd have to think about it.)
Pretty frustrating issue, I don't mind replacing speakers but the head unit is driving me crazy.
I'm pretty sure that the actual NAV is ok.
Anyway, that's what is going on.
Oh, and I don't think that the dealer is going to help me out in any way either, I know I bought the car as is but come on, bring it back two days later with a $2K repair job. Their service dept pulled a fast one on me WTF?
Thanks.
If the dealer is saying it's the head unit and they will be backing it up after repair, I would search that area and see if you could get the parts on your own and get it done cheaper. Of course the dealer could also be saying it's the head unit and repair something else. (simpler and cheaper) I've always worried about my Nav going and so far so good (keeping my fingers crossed). Good luck.
For anyone following, I found this guy in Indiana who is 95% confident he can fix it for $299 with a two day turn around time.
http://www.autobeyours.com/Ebay%20MFD%20listing.htm
Most states have pretty tough laws on dealerships and return policies, so if it's within a few days, I would wager many will by law either have to take the car back and give a refund or make the repair out of their own pocket.
I think my state has something like a 10 day return policy.
sbrown02
09-03-07 11:47 PM
