Creaky windows
Old 10-04-16 | 03:44 PM
honasbone's Avatar
honasbone
Default Creaky windows
All 4 of my windows are creaky when fully rolled up. I have to ever so slightly push down on the window switch for all 4 of them to keep them from creaking. I initially thought it was time to shin etsu again. But after reapplying I noticed it had zero effect on the noise. So then I tried some of that silcone spray all along the window seals. That made no difference either. Any thoughts on what may be causing this and how I might attack it? It's pretty annoying.
Old 10-04-16 | 06:27 PM
LS430cb's Avatar
LS430cb
Did you remove the panels when you treated the seals? If not that could be the issue.
Old 10-04-16 | 07:10 PM
honasbone's Avatar
honasbone
No, which panels need removing? I wasnt aware they needed to be.
Old 10-04-16 | 09:20 PM
LS430cb's Avatar
LS430cb
The door panels, the window channels run the full length of the door. So your only conditioning the upper portion without removing the panels.
Old 10-04-16 | 11:47 PM
ride16734's Avatar
ride16734
Rubber window channel creaked in my car also. Applying shin etsu grease along the top did not help me either. But I pulled down the rubber channel and greased under side of it. My creak was coming from between top of the channel and window frame. Give it a try. I used to roll my window down to calm the creak. Not any more.
Old 10-05-16 | 04:35 PM
honasbone's Avatar
honasbone
Good to know. How did you pull down the rubber channel? Did you need to remove anything else to be able to pull it down? I don't want to break anything accidentally.
Old 10-05-16 | 10:50 PM
ride16734's Avatar
ride16734
Rubber strip can be just pulled down. Then snaps right back in place. No worries. 15min job for all windows.
Old 10-11-16 | 02:04 PM
Vdrummer9's Avatar
Vdrummer9
Smile
Great tip! The creaking was driving me nuts until I greased the underside of the rubber channel. Creaking is gone! Thanks.
Old 10-11-16 | 03:45 PM
honasbone's Avatar
honasbone
I made a first pass and cleared up most of my creaking. It was a rushed job on a cold day. Not ideal. Needs a 2nd pass for sure, but still much improved. Thanks for the tips!
cshaydude
SC- 1st Gen (1992-2000)
12-01-18 12:13 AM
Helogadget
05-16-15 09:38 AM
deja
02-13-13 03:13 PM
jimmer!
12-03-09 09:01 PM
gebo
11-15-02 07:47 PM
