Looking for someone with first hand experience with oem camber adjustment
I have read and been told time and time again that the ls430 has oem camber adjustment. Not much but it is possible. I have had nagisa rca's on my car and I liked the added camber however it was a little to much for my liking. I recently took them off (for sale btw) and my OCD is getting to me because I want my front camber to match my rear camber (there was more in the front then the rear when I had the front rca. I do not car to add more in the rear just want to match the front to the rear). I have been to 4 different alignment shops and they all say there is not camber adjustment on the car. Who can tell me for sure if there is and how it is done.
Fronts have adjustment for camber stock. Rears do not without changing the arms themselves. Rears only have toe adjustment stock. I have changed and adjusted every arm/piece of my suspension front and rear so this is first hand experience.
yeah fronts have the bolts but common for them to be frozen.
the rears have no camber adjustment and theres actually 3 oem arms you can purchase to change up the camber depending on what you need to be in OEM spec.
Thanks guys, I am aware of what there is for aftermarket support I was looking more for oem. the 1-2 degree of adjustment sounds perfect for me in the front. I saw the front bolts and thought it should be able to move.
Thanks again!
-David.
