Doors and Window
Hello
I seem to have a unique situation. Both Drivers side doors will not lock / unlock with the remote.
The remote does work on both passenger side doors
The key will lock / unlock all except the drivers side rear door.
The window in the drivers side rear door is non functioning from the either switch and the remote.
The bottom courtesy lights work in all doors except the rear drivers side door
I have searched this forum and there is no one post with all the same challenges......
Help please.....
Thank you
Help please.....
Thank you
I'm brand new, had the car 9 days.....
I suspect
a) the driver's door actuator is not funtioning
Then
a) the rear driver-side door has no power--at minimum, this door's actuator is not functioning
The key is physically locking and unlocking the driver's door, and operating the other actuators as a result, at least the 2/4 which are functioning, the pass side front and rear
Question for the OP--what happens when you push the black button? I suspect that the two right doors lock. How about when you put your hand on the driver's handle, does anything happen at all (I suspect that nothing would happen as the actuator is not functioning)....
I suspect
Then
Metlupass2
Chicago Lexus Club
06-12-16 08:07 PM
Metlupass2
06-12-16 08:06 PM
tigerm25
RX - 1st Gen (1999-2003)
12
10-02-13 09:21 PM
