Parking/Proximity Sensors acting up
My sensors on my LS 430UL have recently started going off when I'm no where near an object.
Is there a thread related to this issue? Is this fairly common on the UL?
First thing you should do is clean the opaque ring of each parking sensor using a soft brush and mild soap. Often times, the ring is dirty with road debris or bug juice blocking the sensor and causing a false trigger.
With my high mileage '04, the paint has come off the sensors.
When the paint is peeling off in pieces, this upsets the sensors; all I do is scrape the loose paint pieces off and things settle down.
When time permits, I repaint the sensors; they work fine afterward. It's a fiddly job, but doable.
(Large insect remains can act same as peeling paint.)
CCJ22
11-30-12 06:48 AM
