Odd Window Wind Noise Issue
If I'm driving down the road and I lower my driver window for whatever reason..once I put it back up there's wind noise. It seems to be coming from the rear top corner. To get rid of the noise, I put my window down the very, very slightest amount. Wind noise gone. 2 minutes later, I can put my window all the way back up..and no noise.
This is a very odd issue.
Any ideas?
Any ideas?
Is there much lateral play in the window track? Pressure differential while driving can have a negative effect on how the window closes. My RX300 would make wind noise if I opened and closed the driver's window at freeway speeds. If I did it while stopped, no noise...
0011 (12-05-19)
Same issue with my 04 LS430. I can roll the window a touch and then back again sometimes the wind noise will be gone. Don't know if I need to lube the rubber up and then with what?
There's no noise in a 04 Lexus LS430 (Insert there's no crying in baseball effect here)
Try a little of Shin-Etsu grease on the weather strip.
Check out the link below...
https://www.clublexus.com/forums/ls-...shin-etsu.html
No change.
Any ideas?
Any ideas?
tomrx330
11-16-04 12:06 AM
