Oil Analysis on 169K LS-430
Interesting. How did TBN compare to brand new oil?
Did they say why the oil filter should be changed?
Your annual mileage is extremely low, but it's somewhat re-assuring that they told you to keep the oil after 2 years, considering that Lexus tells us to change the oil every 6 months regardless of miles and oil type.
Have you tried a dipstick pump? Sounds perfect for your application. Just pump out a quart and replace it with fresh oil. Beats having to change the oil filter in order to drain some oil.
I have a siphon pump but the oil analysis company requested a stream sample (where Blackstone & some others request a stream or pump sample). Since I have a lift in my shop, changing the filter is quick.
Another Data Point
At my last oil change, I collected a sample and sent to Blackstone Labs for analysis. I have been using Pennzoil Platinum 5W30 for about the last 30k miles, with ~5k mile oil change intervals. For filtration, I use Toyota filters for both oil and air. The air filter had about 25k miles of use at this oil change (and was changed at this time), and I always change the oil filter at each oil change. The vehicle had 200k miles as of this report. The results are about what i expected, as my 1991 LS400 had similar wear levels at ~215k miles. My driving is about 90% highway. I purchased the car at 140k miles two years ago, and based on the service history, the car had mostly regular oil changes at the dealer with non-synthetic oil.
Jeff
Jeff
The link below leads to a summary of what is involved in the collection of a sample and the other steps in the process.
https://www.blackstone-labs.com/abou...o-get-started/
Jeff
Bsavage (07-24-19)
Boomin (11-24-19)
I recently acquired a 2002 430 with 83,000 miles, Southern California car, owned by my aunt-in-law. Came upon this thread when doing a search on capacity. For a 4.3 liter V-8 I find it disturbing that the crankcase holds less oil than my 2015 Golf SportWagen TDI which has 6 quarts. And my TDi is a 2 liter 4 banger.
Most Diesels also have turbos and a much bigger oil cooler due to the oil also lubricating the turbo.
My S320CDI (3.2 litre V6 Turbo) took 8.5 litres of oil where the 4.3 liter V8 LS430 only takes 5 litres.
whizbyu (06-24-22)
LsG86
20
07-24-19 05:32 PM
