New rims for Lexus LS430 but what size?
Old 01-28-17, 07:49 AM
Clifflex
Clifflex's Avatar
Default Thats my LS with 20s
That my ride
Old 02-20-17, 08:57 PM
ls3some
ls3some's Avatar
Default Decent sporty and affordable 18s from tire rack
These are Avarus wheels from Tire rack. 18s front and back. Bf Goodrich comp 2 a/s 235/50/18 tires. Did not want too much bling or to spend a lot on odd sized and expensive tires. Still lots of meat of the sidewall for comfort and excellent grip and quiet yet aggressive looking tire
Attached Thumbnails New rims for Lexus LS430 but what size?-20161113_155736-1.jpg   New rims for Lexus LS430 but what size?-20161113_125238.jpg
FtMyersLS (04-16-23)
Old 02-21-17, 05:14 AM
2KHarrier
2KHarrier's Avatar
I'll have to look, but those may be the wheels I'm eyeing for my 2005. I believe they offered these in Silver as well.
Old 02-21-17, 10:19 AM
Johnhav430
Johnhav430's Avatar
When the Tire Rack has a note that says something like, aggressive fitment, and something about rubbing, do the tires actually rub? I remember a warning about 42 mm offset and more, and virtually all rims do not have such an offset, at least 18"+.....
Old 02-21-17, 08:20 PM
Bhubb18
Bhubb18's Avatar
I've got a GS, so YMMV
Offset is a factor (as it determines how close to the guard your wheel sits), but it wheel width, tyre size, ride height, camber etc are all factors too.
With 245/35/19s on a 19x8+31 I would occasionally scrub on big bumps
With 225/35/18s on a 18x9+35 I don't scrub, because I have a smaller tyre even though it sits closer to the guard.
Old 04-23-18, 05:35 PM
YoungLS
YoungLS's Avatar
Originally Posted by Scootymad
I have 20x10 on the rear of mine with 275/30 tyres. They fit spot on but they need a little bit of camber (not too much) otherwise they'll rub just a little bit on the guards. Up front are 20x8.5 and they clear everything with no rubbing. The car is also lowered
I have a similar set up and I haven’t changed the suspension or camber yet. While driving home with the four stock rims and tires in the trunk and back seat I did rub slightly. What suspension modifications did you make to yours to not rub?Can you have passengers in the rear with out rubbing as well?
kruginator
02-06-19 05:55 PM
jimxms2
11-07-11 01:10 AM
pa06810
02-18-07 11:33 AM
Methodical
Wheels, Tires & Brakes Forum
21
09-04-03 07:12 PM
bobkon_ls430
07-20-01 06:18 AM
Quick Reply: New rims for Lexus LS430 but what size?
